It is currently Thu Aug 21, 2025 5:27 pm
PostPosted: Sun Nov 03, 2013 7:21 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I'm using Cardinal's pore filler on my current project. I'm concerned about cleaning before applying their sealer. What solvent is safe to use?
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Sun Nov 03, 2013 7:36 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I wipe down with DA prior to applying any finish materials.
Brian
PostPosted: Sun Nov 03, 2013 7:45 am
First name: Rusty
Cardinal's product info sheet on their 4760-Series Alkyd Pore Filler says:
3. Clean all grease, oil, and contaminants with acetone or naphtha like solvent
4. Seal the wood and allow the specified amount to dry.
Also, ask Cardinal for their Musical Instrument Coatings Nitro Cellulose Finishing Process instructions.
PostPosted: Sun Nov 03, 2013 7:52 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
To be clear, the filler has already been applied. Concerns about softening/removing the filler while cleaning printed the question.
PostPosted: Sun Nov 03, 2013 8:22 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
*prompted* Dang phone.
PostPosted: Sun Nov 03, 2013 8:33 am
First name: Rusty
Info i have only says:
"Ensure clean surface"
I would think that a light careful wipe down of naptha, DA, mineral spirits, or acetone would do the job just fine after the filler has dried sufficiently.
You can always do a test piece.
Sent from my iPhone using Tapatalk 2
PostPosted: Sun Nov 03, 2013 10:04 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I sand w/320 grit, wipe with dry cloth for water base filler, spray with air hose , and apply 1# coat of shellac for sealer, before spraying or varnishing.
PostPosted: Sun Nov 03, 2013 10:44 am
Last Name: Howard
City: Magnolia
State: Delaware
You need to be careful wiping down between coats. Fresh nitro can be reactivated with something as mild as DA or naptha. After I start applying materials its tack cloth only for cleaning.
Brian
PostPosted: Sun Nov 03, 2013 2:33 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Brian .Is your tack cloth have a solvent/finish in it, or just a plain cotton rag? The reason I ask , is I had a tack cloth once , and it had something sticky in it that picked up dust, but wasn/t sure what ingredient it was ??
PostPosted: Sun Nov 03, 2013 7:16 pm
Last Name: Howard
City: Magnolia
State: Delaware
The tack cloths are sticky cheese cloth type things. They are safe with nitro and other solvent based systems I have used but I extremely caution there use with any type of natural finish like real varnishes, drying oils and shellacs as I have had problems with some of those combinations in the past.
Brian
PostPosted: Mon Nov 04, 2013 7:20 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
I googled ,and found a light damping with thinned tung oil ona coton rag,left in a tight glass jar . Tried it sunday, for cleaning between thinned cabinet varnish.
PostPosted: Mon Nov 04, 2013 9:22 am
Last Name: Howard
City: Magnolia
State: Delaware
[list=]/[/list]
I wouldn't use that when using lacquer but it should work fine for vanishes and other natural finishes. Careful of the rags you choose....lint and small fuzzies can be left behind and you won't see them until you are putting on the next coat.
Brian
